PF2411
Installed Fender eliminator and center stand.
I installed a SW-Moto Center Stand I purchased from Twisted Throttle. It cost $135. It was a relatively easy install as it bolted right to the existing mounts. It looks like the bike was designed from the start to have a center stand. Installing the retraction spring was the only challenge but got that on after a few attempts. This is a great add on mod as it make chain and rear wheel maintenance so much easier as well as checking oil and fluids.
Fender eliminator was an e-bay purchase for $34.95 with free shipping. Just a simple light weight black power coated aluminum bracket. It lined up perfectly and accepted the original bolts with no problem. I used the existing turn signals as I like them nice and bright with the slower original flash rate. They went on on easy as well. I did have to order the plate light separately. I found a China made LED plate bolt light set for cheap cheap at $7 shipped. These replace the plate hold on screws. They stand up a half inch or so and have one bright LED in each pointing toward the plate face. I'll add those on when they arrive.
