I think the best way to cure that nervousness is to find a parking lot and start slow, like maybe 10mph and lock up the rear to learn how your bike reacts to it. Keep working your way up and also see how much pressure it takes to lock it up. I've never really had that fear I guess mainly from riding dirt and locking it up on purpose sliding it around. It's just as fun to me to do on the street bike too, as long as no one is behind you and gets freaked out.I'll have to practice with using my rear brake more. I just get nervous about losing too much traction.
You're doing the right thing... We call it riding within your limit. Start slow and make your way up. The other way around is always a little more tricky and most than likely it hurt!As a newer rider I'm not comfortable in steep leans yet but also still haven't been riding long enough to effectively calculate appropriate speed going into corners. Sometimes I can tell I'm going in a little hot. I realize this at the beginning going into the corner, so I stay more upright and use the back brake slightly to scrub off some speed then lean through the corner at a controllable level for my skills. Seems to be working ok.
For stopping I use front then rear. MSF taught use both. Front kills the speed and rear seems to keep me stable. I also find myself using back brake to scrub off speed when approaching lights that are just going green or I'm approaching traffic that's just starting to move. I don't like just engine braking because people seem to not be paying attention enough to notice so I like my back light blinking (integrated tail light.) Anything helps.
Same here, I use both for complete stops. I also use a lot of engine braking since the bike does drop speed really fast when rolling off the throttle and touch the rear brake enough to let the cars behind me know I am stopping. I almost never touched the brakes in my 2002 Z28 either. The quick stopping portion of MSF was great and taught the use of both brakes.As a newer rider I'm not comfortable in steep leans yet but also still haven't been riding long enough to effectively calculate appropriate speed going into corners. Sometimes I can tell I'm going in a little hot. I realize this at the beginning going into the corner, so I stay more upright and use the back brake slightly to scrub off some speed then lean through the corner at a controllable level for my skills. Seems to be working ok.
