riding Skills: Using the Rear Brake (Sport Rider)
CtrlAltDl
Not a bad article. I find most of my braking techniques come from my dirt bike riding.
I usually use both together. When I'm driving straight and I'm not in rain, hail, or snow (yea it happens sometimes) I use mostly my front brake but also use my rear too. If it is slick conditions I use most if not all rear brake.
If I'm coming in a little too hot on a corner I usually push harder on the rear brake with little or no front brake. My reasoning for that is if you lock up the rear it will cause over-steer (which is usually good), but locking up the front would cause it to under-steer. You never chop the throttle in that situation, which is exactly what you will do if your panicking. In fact I have had a couple instances that more throttle has helped by sliding the rear a little to actually help "steer" into the corner. Of course that is pretty aggressive driving and I wouldn't recommend it unless your on a track. ;-)
mchury
if you think about it your front brake is 80% of your breaking power. Reason being you have 2 rotors and calipers instead of one set like the back. If your front brake feels weaker than your back, you need to look into that bro.
rr_double_rr
I use the rears when I am just doing normal traffic slowdowns, but start with the rear and finish with the front for lights and stopped traffic. Panic stops get a good bit of both just to keep traction and keep it straight.
sammy56
Wow!! There are some really bad habits noted in this thread....and bad advice for some newbies out there.
Any newbs reading this thread, please just read a real book on how to ride and use the brakes effectively. Better yet, take MSF and ask your instructors on best braking techniques.
LB
hattrickhero
I took the MSF course and the Harley-Davidson Rider's Edge Academy of Motorcycling course and they wanted us to use the front and rear brake equally. It is a safe and stable way to stop your bike, but does take practice to learn to use effectively. practice, practice, practice.
e.blackadder
Cruisers are different from sport bikes. Because of the center of gravity, weight and wheelbase, under heavy braking you can transfer all weight of a sport bike onto the front wheel and pull a stoppie. Cruisers are more planted and come frequently with just a single disc up front and beefier rear brake.
I’m assuming cruisers is what you get on a HD riders’ course.
You can find lots good info at the Motorcycle Safety Site: Motorcycle Safety Site.
redwing-2001
actually it is a Buell Blast in the RE New Riders Course - not really a cruiser.
What is supposed to be taught in any MSF Basic Course including the Riders Edge version is to get in the habit of using both brakes all the time. We should go over the effects of weight shift, explain front brake "firm progressive squeeze" to stop quicker and make the new rider aware of using less pressure on the rear brake as the weight shift occurs to avoid a rear wheel lock-up.
At least that is the way I approach it when I teach these courses.
:D
Detrich
as i've been learning to ride canyons, i've been told by more experienced riders to practice ignoring the rear in the twisties... the main 2 reasons that they gave for it are 1) to properly lock your heel into position on the peg, you need to ride on the balls of your feet- not the arch and not the heel, and 2) the rear wheel locks faster during tight turns...
any thoughts on this?
as i've been practicing, i can see that for super sport riders- only because their pegs are further back than ours. but, for the 6r, i think we can get away with "lazier" foot peg position. on the street i still brake with both though... on canyons i move my feet back a bit to get into the locked position.
ninjavillain
i mostly use the rear brake. When I use the front brake by itself it feels weak like it isn't doing anything at all hardly, it isn't until I get some good rear brake in there that I can really feel the bike squat down and come to a stop. Although in most situations I just use the rear brake, and on the freeway I just use less/close the throttle up and let the engine compression slow me down as needed. I learned a few things I've been testing out from the article though, good read for a novice. :)
this could be the same problem I had. The bike was not built right. Make sure on both front calipers there is a pad on each side of the disk. If not the caliper wall doesn't work well as a break. if the pads are not separated by the disk go to the dealer immediately. B1tch them out cause that's a safety issue. The should fix for free and some.
Sander Koop
Sander Koop
BoneJj
Wrong way round, that - means the bike dives when you're coming to a stop? Not recommended... Start with the front and finish with the rear!
I disagree with your methods, I always put a little back first to get the rear to squat and then hit the front. It just works better in my experience, I can get a much shorter stop in if needed and it just works...
Plus every instructor I have dealt with for track racing or even general riding has said pretty much the same thing and I have seen the differences in how it works on tracks during all the demonstrations I've seen.
SurfJunkie
This should all work good and well assuming you:
1. don't have the clutch pulled in.
2. aren't down shifting while applying rear break. ( again, pulling the clutch in while applying rear break = VERY easy to lock up. ) Modulation using the foot is a little difficult to tell exactly how much pressure you have on the lever. Especially in full gear/boots and a major panic situation.
Sander Koop
WorldLavish
The number one advice that I always get as a new rider is to never use the front brake. I always start of with the rear break and apply the front if needed.
Great Article!
Chevyfazer
Great Article!
If someone gave me that advice as to never use the front brake I don't think I would ever listen to anything from them again
Fizzer6R
Great Article!
be very careful of this, you may train your reactions on this method and find yourself in a panic situation locking up the rear. no one is saying to ham-fist the front brake, but it is the one to use most simply because it stops you faster than rear - it's about a 2:1 ratio stronger and will stop the bike in half the distance
Chevyfazer
Couldn't have said it better, IMHO I think new riders get intimidated by their body surging forward when using the front so they end up using the rear instead
