Best map ever!Download the Advgear map... 1-4th are Sport and 5-6th are Touring
I have the Adv Gear Rev B, my other map is for modified cams. Which exhaust setup do you have? Pretty sure the adv gear map works well on most if not all setups until you modify cams.Hey uh, so http://marthymotorcycleexhaustsolution.com/ is down and I installed my exhaust but unfortunately I have no access to any of the maps since it seems who ever was hosting Mathy's site, was also hosting those maps. Does anyone have backups of the maps for Marthy's exhaust?
Hey everyone,
I've offered to host Marthy's PCV maps on my website, I figured it would be easier for everyone to put them in one place instead of having Martin email them to everyone. This first wave is for the Viper can. I'll be working on getting an actual small site setup for these.
Here's what Martin has sent to me in regards to the maps (hope he doesn't mind that I post this)...
Now for the links...
Viper Touring Map
Viper Sport Map
Viper Advanced Gear Map
All of the Viper Maps
Viper Touring Map - Revision A
Viper Sport Map - Revision A
Viper Advanced Gear Map - Revision A
All of the Viper Maps - Revision A
Viper Touring Map - Revision B
Viper Sport Map - Revision B
Viper Advanced Gear Map - Revision B
All of the Viper Maps - Revision B
I hate to have to add one of these, but it's to cover our a$$...
Thanks!
What happens if you don't hook up the speed sensor? Either way I'm cool doing that.
This isn't necessarily related to this thread but has anyone experienced a check engine light thrown after doing the mod? I haven't had too much time to look into it but wanted to see if anyone else might have had the same issue.
Sent from my XT1097 using Tapatalk
Plug the sensor back on the airbox...?What happens if you don't hook up the speed sensor? Either way I'm cool doing that.
Order a set of AIS block off plates, that'll help with the crackleHey guys this is my first post here. I bought an 09 FZ6R last month and have recently put on a M4 full exhaust+ power commander+ K&N air filter on it. I downloaded the PCV 5 map for M4+stock air filter map but my exhaust crackles badly when I am decelerating or downshifting gears. The mechanic who installed it said it is running on the lean side. Any body know the best map for it. (I don't wanna hurt my engine). Thanks in advance.
I heard that just covers the problem. Is there a map that can make the bike run faster and stronger. All the links provided on seem to be broken or not accessible anymoreOrder a set of AIS block off plates, that'll help with the crackle
Sent from my SM-G930F using Tapatalk
Inbox me your email...I heard that just covers the problem. Is there a map that can make the bike run faster and stronger. All the links provided on seem to be broken or not accessible anymore![]()
I will look into it... thanks. Got to have a way to do it here...Marthy, you could just open a Dropbox account and upload them, then just post the link, doesn't cost anything.
Just PM me your email...I too would be very interested and grateful for access to the vast collection of map files by Marthy... I have just received my PCV, and plugging it in and looking at the software is quite daunting for a 'map newbie'.
Any good guides here for it too?
