+1 front and +1 rear? That's only -300 RPM at 70 MPH...Just got my kit from indysuperbikes, and due to a slight stock mishap that was settled over the phone, I now am getting driven sprokets +1 for both front and rear, long story. But we shall see how it works out! I've got nearly 17k miles on my bike with stock chain and sprockets so I'm sure it will feel smoother and have just a small amount of rpm improvements. The speedo will likely still likely be a bit optimistic but that's all right.
There was a change... the speedo sensor is on top of the gearbox, not on the wheel. If you check your speed with a GPS you will see a difference.Need some clarification/help. I dropped 2 in the back attempting to lower my RPM's.
Stock gearing: 6th gear at 6k rpm's =70mph
-2 in back:6th gear at 6K rpm's = 70mph (same as stock)
So what's the deal. Was my speedometer off with my stock gearing and I was really only going 65mph at 6k rpm's? and now taking two from the back has made my speedometer accurate?? I'm kinda confused. Gear guys plz help me out... If there is no change then I'm putting my 46 tooth back on!
I agree... Feels natural.Yea--- thats a bit confusing. After I put in the +1front the speedometer/tachometer relationship was exactly the same. But in fact I was going faster for any given RPM.
To me the feel is more "normal".
16/46... I run 17/44. (Stock 6th = new 5th.... 1 gear overdrive)From a chart that can be found on the attached link (you may have to type the link)....srs6.com/gearratiochart
Our OEM Fornt sprocket is 16 and the oem rear is 44 tooth. This provides a gear 'ratio' of 3.143. I you add one tooth to the front you will get a 'ratio' of 2.933.
The qoute clearly states how to interpret the results.
"Bigger number = Shorter Gearing = Higher RPM's"
Smaller number = Taller Gearing = Lower RPM's
For those using various sprocket combinations, you will find this chart will explain your resulyts.
Cheers!
It's alright. 95% of the time I don't have to downshift to pass on the freeway. 6500 rpm get me 78 mph... this is where I cruise usually on I95. 6K=73, 7K=84.hows your highway passing power? i was going to ask how is it in the twistys but you dont have any down there
haha I could so be inappropriate right now. I'll be good.that was my concern is twoup...i dont care if its just me, but the wifey likes fast
