Since I am new to the FZ6R, I can't say for sure such a system exists. But you would be right in assuming that with an O2 sensor in the right place it should work. That is assuming the fuel map it is trying to compensate for is set up good. As I said earlier, my BMW had issues right from the factory, that fuel map was set so lean that the O2 sensor always tried to keep the mixture very lean, that was it's job. If you looked at the FI system on automobiles, they have half a dozen sensors doing all kinds of checks, the computer takes all that info and makes the adjustments necessary. Motorcycles are not as sophisticated I believe. However with a fuel nanny that is adjustable, you can set it up to work with your engine. It may not be as sophisticated as a system with all those sensors, but they do work well. It isn't that hard to set them up either, you can feel the changes you make easily. Flat spots are easy to detect by the seat of the pants. If it is backfiring chances are it is to lean. However, an over rich condition can cause the same thing. It can be hazardous to your engine to run to lean, an over rich mixture is less likely to cause damage, but it can use more fuel, dirty up the plugs and pistons, and if enough carbon builds up on the top of the piston or in the combustion chamber, it can cause preignition, which sounds like detonation (pinging), but is caused by hot glowing carbon in the combustion chamber. Not lean conditions. Running lean can really be a bad thing, I would never make an exhaust mod like the TBR system without getting a fuel nanny. Pistons don't work well if they have a hole melted in the top.Just get a "fuel nanny" that can monitor the exhaust gases to do what it's supposed to,....right? It must also be placed in a correct spot, past the header collection tube or before the muffler?
10-4"Fuel Nanny" is an expression for the PCV, Juicebox, the brain boxes that monitor and adjusts your fuel/air mixture. The O2 sensor is how the boxes read the exhaust to do the job. Some bikes have this sensor from the factory, ours don't. The values that are set up from companies of the "brain boxes" either have an O2 sensor you have to install or do their maps in house based on R/D.
I hope you post pics up. I am really itching to change the exhaust but since I am not mechanical, I am not sure of the detail. I can figure out the main pieces (headers) but not sure about the Juice box, power commander, O2 senser, now fuel nanny.
I appreciate learning about the mechanics of the bike can see where a novice, like myself, can get overwhelmed and lay down a grand for the full exhaust system.
So I installed it today but I'm still getting popping on deceleration... I turned the Juice box on all modes all the way and I'm still getting it.
Any help?
Yeah, the fact that you are still getting popping has nothing to do with your setup. After my TBR and JB install, I still had it as well. What you need to do is the AIS blockoff. There are a couple ways to do it. Here are links for each methods description. I did the first method and it removed almost all the pops. I still get a few now and then under really hard deceleration from full throttle.
http://www.600cc.org/forum/f91/removing-pops-after-installing-new-exhaust-system-17803/
http://www.600cc.org/forum/f91/howto-install-graves-ais-blockoffs-18684/
Pros: It sounds Great!
Cons: it's too long! I'm using a Yoshimura RS3... I haven't found a correct way to mount it yet..
