lwclancers
Thanks! That would be the lovely state of VA inspection sticker, sighNice job. Dude what's the tag for on ur fork
Got them on. I used a dremel to cut out the bolt and nut, and gorilla glued it to the back. I then affixed to the fairing with a dab of gorilla glue, and then the nut on the back...as well as a screw into the little screw part that was there for the bracket. I think its fine. Ill recheck in a few days.
As far as function, they work great. Ill post a video at some point since its better than pics for the blinkers.
Sent from my HTC6435LVW using Tapatalk 2
Been so long that I don't remember removing the fender bolts. Your gonna have a whole new bike when you're done.Thanks
I like the ZX6R CF mirrors I got...will take some getting used to since I had the stock mirrors for 3 years.
I like the flush mounts alot...Im kind of picky though, so the mounting is bothering me since its not perfect (Ill get over it).
Looking forward to updating this when I get my FE and back signals on. Need to get a 3/8" drive 6mm socket to put on my torque wrench to use as a breaker bar...those back fender bolts on their like crazy.
No. Probably not till 2 weeks from now...put an order in for some Hex sockets (need them to put on a breaker bar or my torque wrench...I'll use them for other stuff too). Have a deadline through next Wednesday and out of town next weekend. SO, she waits....
I have that very same tail light and it's awesome. Well worth the money I paid to get it.I emailed Motodynamic directly to see if anyone has test fit these on our FZ6R.
While there, I saw this:
2009 2010 2011 2012 2013 Yamaha FZ6R Sequential LED Tail Light
That is sweet (play the video)!
Came out great. Although I do need to get a flasher relay, back signals cause fast blinking. Otherwise, all set!
The fast signal is ok, but I find it annoying. I ordered the relay you suggested! Ill post up videos and a few more pics (of the HID retrofit too) soon!
No, they wouldnt work that way. The opening in our fairing has a recess and an edge. Youd have to cut away that edge within the recess to allow anything to fit through....and then youd lose the ability to tighten any sort of adapter down.lwclancers, think those flushmount turn signals you installed would fit inside the cowling? I was thinking of using the adapters with it to make a nice clean set up along with a pair of proton turn signals on the side.
Basically splicing the female adapter that comes with it to the female adapter from the bike and then using those two female adapters and connecting the male adapters from each light to them. If that makes sense...Basically cleaning up the wires as best as possible and maintaining things plug and play as much as possible. Then using a separate led relay instead of the ones that come installed in that led flasher relay you have.
