stupid things that kawi does with some parts. I have 2 forward facing lights at the top of either side of the headlight that are white lights that are always on.Says it works with LED's as well as incandescent bulbs. So should work for you. If your's are stock why don't they have DRL capability?
So I guess they think I don't need amber running lights...
I want to come up with a good LED conversion for those next to the headlights but the problem is that I want to do LED and if I do LED it's going to be 1 watt LEDs so I will then need to have some heat sinking for them, I just have to come up with a process for that. not too worried about it right now though.
Edit, OK, looking at the specs on them:
So there may be an issue of how much draw they will have, I will have to look up the bulbs and see what kind of wattage they are before I order them. I really like this idea though as it will help to get my day time visibility up. I'm all for that!Blinker Genie
High-Power capability of 12A/ 180 Watts (2A/ 30 Watts recommended).
OP if you want to get some first cheap side markers:
www.dx.com
Cheap china stuff that works pretty decent, just takes a while to get here.
