does anyone know what size cap fits the filter. on the vehicles at work we have a black cap that fits right over the end of the filter w/ a 3/8" drive hole. obviously its too big for these filters. would a 67/68mm be close?
Service manual says it's 64.2 mm, Yamaha part #YU-38411.
The closest in my collection is a 65-67 mm, which in my experience ain't close enough.![]()
How much oil is everyone putting in with the oil filter, the little manual states to use 2.96 qts, but in ther service manual it says "total amount" is 3.5 but says to only use 2.96 with an oil filter.... I am confused now
i wonder if duct tape wrapped around the filter will make it tighter.
Makes sense now, went out to the garage and checked the dip and we are good to go. I also finally moved the bars back a bit as they were up way to high and raked them back a bit and moved my levers to where I liked them as well. Also upped the rear shock from 3 to 5. Will see how it rides now, the rear was on the soft side for me
I personally use K&N oil filter. I like the 17mm nut end, easy off - easy on .
Tnx cbzdel for the recommendation ...![]()
Nope, thus here is Steve's (wrightme43) list!
Oil filters that will fit
These Oil Filters
have 20 x 1.5mm threads,
14 psi by-pass valve,
anti-drain back valve,
2.3" O.D. gasket
2.5" to 3.5" long.
If you have the room, I recommend the longer filters.
Motorcycle Filters.
None are recommended.
AC Delco PF2135
AMSOil SMF103
Carquest 85358
FRAM PH6017A
Honda 15410-MCJ-000
K&N KN-204, about $13. Metric nut on end for easy removal.
NAPA Gold 1358
Purolator ML16817. Imported, not made by Purolator.
STP SMO 17
WIX 51358
Recommended filters.
All have superior
filtering.
About 2.5 inches long.
Purolator Pure One PL14612, about $6.
Mobil M1-108, about $12.
Made by Champion.
Bosch 3300, about $6.
Made by Champion.
About 3.25 inches long.
Purolator Pure One PL14610, about $6.
Mobil 1 M1-110, about $10.
Made by Champion.
Bosch 3323, about $6.
Made By Champion.
WalMart SuperTech ST7317,
about $2. Made by Champion.
Buy these filters Automobile Filters,
about 2.5 inches long.
AC Delco PF1237
Baldwin B1400
Firestone TF2876
Hastings LF113
NAPA Gold 1365
Purolator L14612
STP S-02876
WalMart SuperTech ST6607
WIX 51365
Automobile Filters,
about 3.25 inches long.
AC Delco PF-2057
Auto Pro 2356
Autopride CF240AP
Baldwin B1402
Carquest 85356
Carquest Red B4620
Casite CF240
Castrol 7317
Champion Labs Ph2867
Defense Filters Dl7317
Deutsch D-370
Federated Filters LF240F
Automobile Filters,
Fram Double Guard DG7317
Fram PH7317
Fram Tough Guard TG7317
Fram Xtra Guard XG7317
Group 7 V4610
Group 7 V4620
Hastings LF240
Mighty M4612
Motorcraft Long Life FL-821
Napa FIL1356
Napa Gold 1356
Parts Plus PH2867
Pennzoil PZ-109
Penske 7317
Powerflo SL14610
Powerflo SL14620
Pro Gauge PGO-4620
Pro Tec 164
Promotive PH4610
Pronto PO3593A
Purolator L14610
Service Champ OF-4622
Shell SH48
Shell SH529
Stp S-02867.
Valvoline VO50
Warner PH2867
Wix 51356
This info is available at Motorcycle Oil Filter Cross Reference
I will link to thier oil filter testing as well.
I highly highly recomend the purolator pure one filter PL14610 for less than 6 dollars it is one of the finest available.
While I'm not one to tell anybody what to use/not use on their bike, I found the following on the Purolator website:
Motorcycle Filters
What About PureONE
If you're thinking you want to install a PureONE oil filter on your bike, please think again. PureONE oil filters are designed for vehicles, not bikes. Because of PureONE's high efficiency, the motorcycle oil pump may not be able to handle the pressure. The Purolator motorcycle filter line is designed to meet the specific needs of a bike; therefore we highly recommend the use of a Purolator ML filter over a PureONE oil filter.
Again, this is from Purolator. Use what you want.
Cheers!
