My 2009 FZ6R has under 5,000 miles and just recently the speedometer started to rattle when riding. Anyone know how to fit this besides sticking some foam underneath it. The foam looks sloppy.
Thanks Community!
do you have a hi-res version of this?
Mine does the same at 4200 RPM's. It's within the trim pieces under and around it, not the speedo itself. I have yet to fix mine. Although, I have a few ideas the next time I get the chance.
It is just the speedometer that rattles, not the digital display. I like the duck-tape flow chart but don't think that will work for the problem haha. I will try to look for a part missing or loose connection. If I cant get an easy fix I will probably just stick with stuffing a little black foam underneath the speedometer.
Any other ideas?
