Giving washing the 6R is very much like washing a car.
1 - Water your bike down with a water hose (do not use high pressure hose).
2 - Soap using microfiber for any high gloss areas (plastics and tank) and any old rag for the rims, swing arm, and other rough areas.
3 - Rinse with water hose.
4 - Dry up with microfiber cloth
At this point I usually take a slow rider around the block to get air to dry any water left in the hard to reach areas and warm up the chain a bit for the next step.
5 - Clean and lube the chain
6 - You're Done!
You don't have to worry about covering anything on the bike. This machine is expected to ride through rain, so a bit of water wont hurt it.![]()
Dry: electric leaf blower. No kidding - it quickly drives the water right off for a spot-free shine.
I usually pass on riding right after to dry it... I just grab the leaf blower.... shortly after I started doing that, I actually saw it recommended in a motorcycle mag as a quick dry solution...
oh, just make sure you don't have a blower full of stink bugs first....fortunately, I was blowing leaves first, so they all got spread on the lawn, not my bike
