Chain maintenance
Blue-Sun
MikeN02
I'm starting to get a little rust on the side of the chain... pretty odd.
I've been keeping up with the maintenance, every 600 miles or every ride in the ride or wash.
matt_not_andrew
Does anyone know the average useful life of a chain if it is properly maintained?? Miles??
Thanks in advance
Depends on number of factors - how you ride, type of chain lube, gear ratios etc. I think you should be happy if you manage 6-10k out of a stock chain with regular maintenance. You should be able to double that if you use a chain oiler. I have a Scottoiler on every bike I own besides my crosser and normally it's about 5k between chain adjustments.
I would personally avoid WD40 as a cleaner and lube cause it can remove the oil from the O/X ring which is the part you really want to stay lubed. Before using the scottoiler on bikes I used Kerosene to clean the chain. I'm told it's kinder to the rings and cleans it up a treat. After brushing it on with the girlfriends toothbrush and giving it a good scrub I would wash what I could off with water and then take the bike for a couple of mile ride to fling off the most of the kerosene and warm up the chain. Then apply your favourite lube to the warm chain, wipe away any spills or excess and leave to set/dry/penetrate.
With the scottoiler, while it does fling off because it's a total loss system, it does prolong chain life in my opinion. It makes for a messy rear section that need more vigorous cleaning but its generally a fit and forget option. Apart from top ups every 500miles or so which takes all of 1 minute and replacement of the delivery nibs when required, it keeps your chain clean and lubed. If you ride in a country where they salf the road in winter then remember to turn up the drop rate in the cold months.
On the WD40 note, I have spoken with a chap who took an XR400 across the Sahara desert and he swore by it for both cleaning and lubing. He would clean the chain every morning with WD40 and a brush/rag and then not bother applying any lube to it afterwards. The reason for this was any viscous lube would make the sand stick to it and effectively sandpaper the chain and sprockets together causing premature wear. Same reason why most people who ride dirbikes off road use a not sticky type of lube and more non setting oil base type. He was running an Oring chain and could afford not to use lube in those conditions. For normal road riding I would recommend regular maintenance and lube.
Just my 2p worth.
Administrator
Staff member
That's likely just surface rust. I see some every now and again, especially after several days of riding in the rain before I get some dry days to redo the chain. It always comes off when I clean though.
Blue-Sun
TigerGenetics
Just wondering if anyone has used Seafoam Deep Creep to clean their chain? Guy at a local shop told me he uses it as well as a buddy of his who rides a 'busa.
Roaddawg
Just my 2p worth.
I swear by WD40 as well. I use it to clean the chain (as well as other greasy parts and to remove that damn DB windshield sticker) and then wipe it down with a rag. I've heard that you SHOULD NOT use a brush on o-ring chains as it will force grim in between the o-rings and also rub on the o-rings as well. After I wipe the chain clean, I then thoroughly lube the chain with spray wax. I have over 18k on the stock chain and sprocket and there very minimal (if any noticeable) wear. I also clean and lube once a week (or every 500-600 miles)
motoneta123
Question: every how many miles should i clean/lube my chain i been riding 150/200 miles a week in So Cal, it never rains here... my last bike was a kawa vn750 (shaft drive) so i have no idea about chain care could anyone please tell me? thanks
Fenixgoon
so here's a dumb question:
in my excitement to clean my chain for the first time, i forgot to go for a ride! i still gave it a thorough cleaning (kerosene + toothbrush) and lubed afterwards. how big of a deal is it? i'm guessing the next cleaning will be after only a short period instead of ~600 miles?
Rao
Yeah, I'm Posting in this thread... alot of good information in here, but I've run into an interesting situation that has me stumped:
I cleaned my chain for the first time today, as the rear sprocket was making alot of noise. After cleaning and lubing the chain, I take the bike for a spin, and immediately notice the rear sprocket is super quiet. (yay)
However, after about 10-15 minutes, I notice the front sprocket is making alot of noise. The tinny high-pitched chain noise only comes up when I'm using throttle. When I'm coasting, engine breaking, or using the clutch, I don't hear a thing.
Any Ideas? I'm certain I used ample amounts of lubricant wax....
roadrat
I'm pretty lazy so after I clean my chain I'm not always up for bringing it down off the stand, gearing up and riding it to warm the chain up for lubing... so I use my wife's hair dryer. Ha! Works great. And... no pressure to lube fast before the chain cools... I just warm up a section at a time. Gotta get a dryer just for my own use though - she hasn't noticed yet but eventually she will. ;)
linkgt
Wait, after you clean the chain you're supposed to warm it up before lubing? Never heard that before till now...
Chucker
Active Member
I get this on mine as well. I've checked and rechecked to make sure everything is lined up as it should be. I think it's the chain hitting the plastic guide in front of the front sprocket. I've never been able to see any adverse affects on my chain or sprocket, so I think it's OK.
