You never had to install the block off plate... I can tell. Well to answer your question look at the label on the LH side of your swingarm... amasing the kind of info you need on the go.
For doing the job... well just to give you a picture. 1- you need to mesure your clearance before you do anything with a warm engine is better. 2- You need to remove the cams and lifter mesure the shims in place between the lifter and the valve, then go get what you need. Put everything back together, AT THE RIGHT PLACE! Mesure again, go thru the whole process if you screw up... Then when your happy with all the numbers, put all back together.
If you never did that before... it might be easier and quicker to drop off the bike and ask to do overtime at work! By the time you figure out how to squise the valve cover out of there, you will be kicking yourself in the butt saying WTF I was thinking!
