Hey everyone,
I've offered to host Marthy's PCV maps on my website, I figured it would be easier for everyone to put them in one place instead of having Martin email them to everyone. This first wave is for the Viper can. I'll be working on getting an actual small site setup for these.
Here's what Martin has sent to me in regards to the maps (hope he doesn't mind that I post this)...
Viper Touring Map
Viper Sport Map
Viper Advanced Gear Map
All of the Viper Maps
Viper Touring Map - Revision A
Viper Sport Map - Revision A
Viper Advanced Gear Map - Revision A
All of the Viper Maps - Revision A
Viper Touring Map - Revision B
Viper Sport Map - Revision B
Viper Advanced Gear Map - Revision B
All of the Viper Maps - Revision B
I hate to have to add one of these, but it's to cover our a$$...
Now for the links...Marthy said:Here's few things about those maps. First of all, this is the best I could come up with. I made 3 maps. They are pretty much all the same, the only difference are the crusing range (4500 to 7000, 5 to 20%) in the "Touring" version. With those numbers (+5) the bike run good and it's on the safe side. (I ran 0 for a 150 miles trip yesterday and everything was fine. I just felt it was right on the edge...) Using +5 should be on the safe side for everyone.
The advance gear feature is the best of both world. Instead of having a "MAP SWITCH" and alter from Sport to Touring map, it does it for you. Gear 1 to 5 are preset with the Sport map. 6th gear is preset with Touring map. It can be change for your needs. I migh change mine for 4th, 5th and 6th with the touring map... Or just change the crusing mode to +10 for 4th & 5th. You have the idea, it can be change for what ever needs... I will suggest to always save on a different name if you make any changes, it's easier to track back your progress or go back where you were if you don't like the changes. One thing here, if you don't use the stock gearing you need to connect the Speed/Gear sensor to the PCV and recalibrate your SCALLAR number. Read instruction in the PCV manual.
Now here's few piece of advise about the Acceration Pump feature. The 75%, 30Rev & 20% are, what I would consider, agressive setting. Since the bike is quite detune and under power, for the experience rider they are very manageable. It gives a solid punch on hard acceleration.
Now for the less experience rider... I hope those will be honest with them self. Try the map without the A/P feature for a bit, then use the intermediate setting... make you're way up to it. With the "expert" setting (had to give it some sort of name) you can't just dump the throttle like you use too with the stock bike, espacially coming out of a corner (still leaning...) You need to have some throttle control.
Enjoy the ride... and be safe!
Viper Touring Map
Viper Sport Map
Thanks!DISCLAIMER said:Please be careful while modding your bike. Use these maps at your own risk. Even though these maps have been tested and do work, we won't be responsible if something were to happen to you or your bike due to the use of these maps. If you have any questions regarding these maps we strongly suggest you PM Marthy.
