A turbo would be sweet. I feel a frame-twister, coming out of a corner, in the making!
Let me play with the R6R TB first....then we can talk about feeding crack to my engine.....jeeesh....
Ok, I'm just going to throw this out here. If you are looking for the biggest bang for your buck, i.e. HP/$.....then you need to look into a power adder. In other words, maybe you should shift your thinking to consider adding a turbocharger or some nitrous oxide. It's the quickest way to get hp gains and still retain a fairly stock power/torque curve. Especially with nirtous oxide, as you can control how much, when and how often it gets sprayed.
Just some food for thought.
You are killin' me Bro.....my wallet just looked at me and squeeked and a moth flew out.
I think it acts like an x pipe and helps with exhaust scavenging at higher rpms. Each exhaust pulse helps to pull the next pulse from the connected opposite side. The outside two don't need to be connected because they draw from the inside two at the 4-2 intersection?
What is the stroke rotation as it relates to the pipes? That may help explain a little more. I.e. 1-3-2-4? Exhaust pulse 2 helps pull exhaust pulse 3 out of the chamber and down the header?
I could completely be talking out of my ass.
Interesting discussion here... Let's start with throttle body. It's all about air speed. As long as air speed stays 70% below the speed of sound your good at the rev limiter your good. Having bigger throttle will just kill your throttle response in the mid range. Bigger doesn't mean better!
For the cams it's a bit more technical. Lift have nothing to do with HP. Lift should be around 30% of the valves diameter. The gain is very minimal pass that point. Using hight performance valves with a smaller radius is the way to go. But $$$? The power come from the duration. More duration (late intake valve closing) more top end.
We can go on like that for a while. The bottom line is an engine is like a massive air pump that need to work in perfect harmony all together. So you can't just do 1 thing, you need to do it all! By example, if you want to run faster you need to train both legs. If you train only your left leg to run faster it will not make you run faster.
So better air filter, exhaust, fuel delivery is all you can do unless you are ready the spend the big $$$. Even there, it's all about compromise! Good luck Buddy, hope it will help you a bit!
Why not use the FZ throttle body? Our engine is totally based on FZ engine and the compression ratio is the same! I think it would be easier!
