Sidi ST Air Boots
San Diego (Lakeside)
www.facebook.com
Those are sweet boots and the braces on the sides look like they have great torsion control... Gotta protect our ankles at any cost, they're complicated to repair. My kid broke his ankle on a skim board and he had all these pins and screws in his ankle and he's never really recovered fully.
great looking boots.
one question, how well does that cam lock work at the top of the boot?
does it feel like it could pop loose on heavy impact, how adjustable is it?
STG's review just says its the same as what some offroad gear uses, but that doesn't help me.
idk about them.. when i ride i like to be able to walk around in public and not look like a tard... they are not very fashionable
SMH at people worried about fashion over safety when riding.
Boots look good Jon!
Also, full length boots aren't that bad to walk in. I walk in mine all the time.
My experience with Sidi is that they are great riding boots but terrible for walking.
This is typical considering they are racing boots and not a walking/riding hybrid.
I have the Alpinestar S-MX-5 boots that I bought when I purchased my FZ6R.
I had a friend that has major ankle problems from wrecking on a motorcycle. They are more comfortable to wear and a lot easier to walk in but don't have nearly the side ankle protection of my Sidi Vortice Air boots. I've raced with both boots and the Sidi are far superior on the track. Also just about every piece of the Sidi boots come off and is replaceable if you need.
I put the magnesium toe sliders on the S-MX-5 boots. I think you can upgrade to the Vortice tor sliders pretty cheap and have magnesium toe sliders too. Those boots you bought are very nice.....:D
I have the sidi cobra boot, (yes, I know this topic is about the st air) and I absolutely love these boots. Considering they are on the lower spectrum for sidi boots, they rock.
Just a bit hard to walk in.
I have the Alpinestar S-MX-5 boots too, not bad to walk in. If I'm going to be in a crowd or something I wear my Red Route kevlar jeans and just put them over the boots.
Seriously, though, here in Cali people wear all kinds of weird crap. Compared to a dude like this I feel pretty cool in my motorcycle boots.
C'mon now.....you are from Vista...don't be hatin on Venice....:D
i picked up a pair of Sidi ST's a couple months back too and have been riding in them in the canyons.
and, i think they're GREAT, -but- NOT PERFECT.
i would still recommend them, but there are a few issues with them that you have to either be able to live with or adjust to. some of these things might drive some ppl crazy. some not...
PRO's:
- rugged & great protection for the foot, ankle, and shin.
- very good toe & heel sensitivity/ response while riding.
- breathe very well.
- comfortable fit while riding.
- look great.
CON's:
- slightly on the heavy side, weight-wise.
- sizing is a bit wide at the ankles.
(i'm a perfect size USA8 foot, but the smallest size the ST's come in is EU42, which is USA8.5. oddly, the ST's fit me perfectly- except they are slightly roomier than i would like around the heel. none of my other shoes or boots have this issue..)
- strictly for riding and not really a boot comfortable enough that you could wear around all day at work.
- squeak like a mother f'cker when you walk around.
(i've already had to wd-40 the ankle joints on both boots twice!)
- overly complex strapping system.
(think getting in & out of old-school style ski boots.)
(also, the inside buckle of the inside strap creates a small hump. when leaning/ cornering, it took me a while to get used to my outside leg hitting that little hump against the bike. i've had to adjust to where it is and shift my leg just a tad to clear it. i have to admit that initially this was very annoying to me.)
- expensive at $400...
i haven't ridden in these in summer time yet. but, my previous boots were non-perforated too. and, i don't have sweaty feet. so, for me the non-perforated model works fine for both summer & winter. probably even better for winter.
Hope this helps...
My Vortice boots do the same thing....I don't care and just let them squeak....:rolleyes:
For $500.00 bucks I want people to notice what I'm wearing......;)
john> again, wd-40 the rotating joint cups and they instantly stop squeaking. :)
it's not a deal-breaker for me either. but i just think for such a pricey pair of boots the least SIDI could've done is to have lubed them from the factory... You know?
WD40 is Mostly Kerosene 51% and mineral oil 15% with 25% LPG.
Maybe a squirt of chain wax will be better.....it won't harm the expensive plastic....:D
I see... I never thought of that part. But, then again, I didn't spray a lot of it- just a tiny squirt thru the red straw into the snall opening I could get after rotating the ankle a bit.
I used the rotation motion of the joint to then spread it around inside. The rotating joint on the boot has a near flush mount point. So, I covered up the spray area with a rag to prevent bleeding.
But, taking a step back. Boots & gloves have a life span. So, as long as it doesn't corrode the plastic for the lifespan of the boot it should be ok I think.
Is there even such a thing as plastic lubricant? Maybe some KY? Hahahaha. Ok. I won't go there...
xP
