Break light problem
UncleHilty
My rear break light doesn't go on when applying the front break. Ok when I do rear. Everything is stock so I didn't screw it up myself. Any thoughts?
Thanks
latony007
hmm, if nothing has been touched id check the fuses. Seems odd there could be a frayed wire or something. im sure it runs in the wire bundle under the seat so id check it for breaks or issues.
leem00
Sport touring Member
Bert-Aus
Could be the connection at the either end too,
try disconnecting the clips, blow into to clear any debris
if there is a build up of crap in there or any corrosion get a cotton tip with methylated spirits to clean to connections (internal)
alaskanflyboy
Premium Member
latony007
Thanks everyone. Once it stops raining here I will see if any of you are bike whisperers!:)
NO kidding, its been raining for 2 days, enough already! LOL
UncleHilty
Problem solved! I think one of the connections up under the housing at the grip came loose. Un plugged. Re plugged and presto! Working break light. Thanks every one and LAtony let's meet up for a ride in the new year!
