I ordered a clear set.its $5 bucks cheaper on their web site. already placed my order.
I see what you're saying but you can use the with the oem turns either in series or parallel. A brighter brake light is good to have!! You can check them out when i get'em!Not the biggest fan of this.
Ill keep my blinkers separate from my rear light.
Whatcha got?I don't have stock turns any longer.
I made a lil license plate holder that has blinkers on it. I just couldn't stand the stock rear fender.Whatcha got?
I absolutely love it. I have one issue currently, I have the proton front flush led's and that is causing the sequential turn signal to not work correctly, I've got the resistors on the way to correct this, once I install them I will review a bit more thoroughly.Interesting.....for anyone who has received/installed this integrated brake light system please let us know how you like it. I have to admit I like the YouTube demo but is it as advertised? Are you happy with it? Many thanks in advance!!
how can that be possible? you need to make sure you didn't unplug something else as the light circuit is independent of the abs.I have one of these on my bike (XJ6F, same as FZ6R) but it has upset my ABS system
how do program this, the instruction says pull a rubber plug from the housing to see the button, but where is the rubber plug? the instructions came with a pic that does not match anything on the housing!It works great, much brighter than stock. It's entirely riders choice, but I honestly dislike the stop alert feature. I disabled it the moment I got it. In my experience of owning it, the flicker appears more like a malfunction than an alert. Entirely up to you of course, but I recommend disabling it.
I found it, lol. button is inside the housing and there is small hole covered with a tape like material in the back to access it. damn the instructions!almost like you ordered a who'sa-what and got a whatcha-majig?
