Big props to Martin (AKA Marthy), Rumpig from this site and FinalImpact from the FZ6 Forum for being very thorough doing all the hard research work on this mod. Maybe not for the faint of heart because if you don't do it right, your motor knocks itself to death and becomes a molten blob of aluminum.... but don't let that bother you!
So you can search the names above to get the details, which I won't repeat here. I bought a second timing trigger in case I messed up filing it, so my bike would not be down. I think I paid $15 shipped. Mine was used from a FZ6, but it is exactly the same as ours. They are only $5-$6 on-line new, but the freight kills ya. I got mine on E-bay.
Here are my secrets to success doing this:
1. Buy a second trigger wheel if you want to be safe. I got it right the first time, you probably will too, but it's cheap insurance
2. Buy a new cover gasket. It is metal, but has some gasket goo on it from the factory
3. Index the wheel (mark it) before you remove it. Without taking a cover off the other side of the engine, there is not an easy way to hold the shaft from spinning when reinsatalling. You can use this mark to impact wrench the bolt back on, carefully, to get the torque close enough
4. Use an impact gun to remove the trigger wheel. Easy peasy.
5. Use a good pair of digital calipers. This is pretty precise stuff here! I believe our bikes come OEM at 6.5 degrees idle timing. The higher performance version of our engine comes OEM at 10 degrees. maybe it was 10.5 (?). The timing trigger has a nub on the back of it you want to file so it can rotate it 3-4 more degrees clockwise (more advanced) within the notch on the shaft. I choose to be a bit conservative, because filing exactly straight is not a perfect science and I live in a hot climate where timing too advanced can cause knocking.
6. The nub on the back of the wheel that fits in the shaft keyway, starting width is 0.197" wide (un-filed). I verified this multiple times, zeroing out the caliper to get repeated same results so I wasn't holding anything crooked.... which is easy to do.
My target was between:
+ 3.0 degrees = take off .027" (that's not much folks) Final width after filing: 0.17" = Final timing at idle: 9.5
+ 3.3 degrees = .take off:.030" Final width after filing:0.167 = Final timing at idle: 9.8
You can see from the pics how I ended up. Pretty happy with my result.
7. I used a fairly large file with smooth surface edge so I would not scar up the wheel to badly. I finished with a jewelers file. The smaller file was much harder to keep at 90 degrees. Not only is that very small amount to file precisely, but so is keeping it square. File a little & measure frequently!!!!
8. Several others who documented their doing this either peened the other side of the nub, or even went to the extent of welding a bit of metal on and filing the other side to get back to the original shaft keyway width of 0.197". I was going to peen it, but after talking with Martin and seeing for myself, I don't think there is any real need to do this. So I ended up with a narrower nub, that when inserted on the shaft you could rotate it approx 3 degrees, back and forth. The thing to realize is, this wheel has no force applied to it when in use. All the bolt does that holds it there, is hold the weight of the trigger on the end of the shaft when it spins like crazy. I suppose there is some slight magnetic force from the timing pick-up. But that is minimal at best. When you tighten the bolt clockwise it automatically forces the wheel to the advanced, clockwise position against the right wall of the keyway... just where you want it. The .027-.030"" gap on the other side is immaterial. Locktight and approx 25ftlbs and that wheel is never moving.
9. I tried using torque wrench to reinstall, but as peviously documented the shaft and cam chain spins too easily. So I very carefully used the impact gun to tighten back to the mark I indexed before I removed it. I used lock tight. Close enough. Thank you Martin for this tip!
So what are the results? GREAT! My research said that 1st & 2nd are ignition retarded by the ECU, but 3rd and up are not. So my expectation was little improvement in the first two gears, and something noticeable starting in 3rd. Here are my findings:
a. Bike starts faster, that is it doesn't crank as long before it starts. That's a good thing.
b. First gear definitely pulls harder from mid to top RPM. Now, when I roll on first and hold it open, the front wheel gets lighter during the top third of the rev range. Noticeable improvement. I don't have to rip open the throttle in 1st to get air under the front tire.
c. 3rd gear is stronger no doubt.... but it's kinda hard on my country roads to fully rev out 3rd & 4th or your approaching double digit speed. I believe there is discernible improvement though
d. The bike sounds different. So my bike is loud as hell with essentially a Marthy exhaust using a Delkevic DS70 can, block off plates and a fully cut airbox. Seems silly to say it, but the bike is a bit quieter, and it just sounds a little different. Not good or bad, just slightly different. My "justification logic" says it sounds better. Maybe it sounds a little smoother??? Maybe me imagining that.
e. It should improve mileage a tad, but I have not verified this.
What are the downsides of this mod?
1. Filing off too much or not filing it straight, advancing the timing too much and getting knock (ping), which comes from premature detonation and is hard on, or can destroy the engine. You should get enough knock warning before that point though. Listen to your bike.
2. Where before you can use Premium or Regular gas, now you need to use Premium or it will most likely knock, especially in hot weather. If you commute a lot and want to use cheaper Regular gas, this is not the mod for you. I doubt any mileage improvement will offset the cost of Premium. I used Premium anyway, so this was a non-event for me.
3. You may want to (need to if you advanced the timing too much) go to one heat range colder plug. It is not necessary depending one the quality Premium gas you get, how hot it is where you live and how much you advanced the ignition. If I get any knock, which I have not yet and don't expect at approx. 9 degrees, it's easy enough to go to colder plugs.
4. You need to sit further forward to keep the wheelies down
The best part is I only have a few bucks in this mod for the used trigger (which technically I did not even need... but now I can go back to stock if I want to without buying one in the future), and the gasket.
I am happy and recommend it, however your results may vary and I am not responsible for your bike, and I don't recommend smoking or cage fighting either so choose wisely!
My next, an last mod coming up is to instal my -1 front sprocket. I am going to ride the bike for a few days if the weather cooperates before changing the sprocket. I think that will be enough for me, not doing + 1 or 2 in the rear. I don't ride long distances on the highway all that much, but don't want it buzzing too high at freeway speeds. I think the timing advance and 15 tooth front sprocket will liven it up enough for me. Yay.
