Didnt want this to be my first post but I wanted to get this information out there to anyone who wants to do this mod.
Just to let you know, the directions that come with this product have the wrong wire listed for the crankshaft sensor. Directions state to use the dark gray wire when in fact you need to use the LIGHT gray wire (almost white in color)
I have contacted Healtech about changing their directions so lets see what happens.
Use this wire for the crankshaft position sensor
On the other hand, the install was rather simple. Its essentially just plug and play and splicing 2 wires.
My quick instructions
There is only one 3 pole connector under the gas tank. This connecter is the speed sensor. Connect the Gipro in between the speed sensor.
Connect the black/green wire from the GiPro to the light grey wire on the crankshaft position sensor. This sensor comes right off the crank case. You can actually see this wire when looking at the side of the bike.
Connect the red wire from the GiPro to a 12v source (brake light, blinker etc)
Snake the wire loom through the frame and mount the led unit right on the dash and your good to go.
Follow the directions included with the unit on how to program it.
I wish I took more pics but this is what I have. Any questions please ask
