khasfz6r11
Has anyone added a USB port to their bike?
If so any suggestions on which product and where you connected would be cool.
Thanks!!
Thanks!!
How did you set up the high beam garage door opener??I haven't put a USB port on the bike, but I hard-wired a 12V outlet to it. I figured it would be more useful (you can buy an adapter to USB). I even use it to power a 12V air pump, to fill an air mattress while camping with the bike. I just keep it under the seat.
I installed this double usb port to my dashHas anyone added a USB port to their bike?
Thanks!!
I went to the website for that one and it says "discontinued".I installed this double usb port to my dash
http://www.600cc.org/forum/f101/fyi-travellers-double-usb-charge-point-26714-post361552/
On my cruiser I just put the cord straight into my saddle bags so I just throw my phone or whatever else I want to charge in the bags, plug in and go.This is a great idea, thank you for the great advice. I am also going to be doing some long distance travel. When I do that I will just run the charging wire to my tank bag so I can still check GPS visually.
I just purchased a Bluetooth helmet, haven't even gone for a ride with it yet. Seems like it works fantastic!
I used one of the remotes that came with my garage door opener. It's now a permanent part of the motorcycle. I opened it up and found the two contacts that showed continuity when I pressed the button. Then I soldered these contacts to a SPDT relay on terminals 30 and 87. I found the high beam switch wire in front of the gas tank, to the right of the steering head (yellow if I recall). Soldered terminal 85 of the relay to that wire and termnial 86 to ground.How did you set up the high beam garage door opener??
This is so cool! I am definitely going to try this!!I used one of the remotes that came with my garage door opener. It's now a permanent part of the motorcycle. I opened it up and found the two contacts that showed continuity when I pressed the button. Then I soldered these contacts to a SPDT relay on terminals 30 and 87. I found the high beam switch wire in front of the gas tank, to the right of the steering head (yellow if I recall). Soldered terminal 85 of the relay to that wire and termnial 86 to ground.
Flick high beam, garage door opens!!!
You like your Oneil? I am looking at the fastrack ii I might get. I like the "blinc" in that I have currently 3 different brands of helmets and they all connect together with helmet to helmet.I got the Blinc as well in the O'Neal Commander. Seems to work really well in all the scenarios that I bought it for!
I love my Commander with Blinc, works very well even at highway speed I can hear everything perfectly!You like your Oneil? I am looking at the fastrack ii I might get. I like the "blinc" in that I have currently 3 different brands of helmets and they all connect together with helmet to helmet.
i will have to check into them, the fastrack is down to 150$, some guy was selling the oneal tirades with blinc 3 and FM radio for $100 but said the display on the blinc (guess they added a small LED) did not work. Jafrum has some new Rebel Hold with blinc and drop down visor for like $110 but they have not had any in stock despite the fact it says new.I love my Commander with Blinc, works very well even at highway speed I can hear everything perfectly!
Very reasonable price for the features. Tinted flip down visor is very smooth and easy to operate as well.
There are some accessories like outlets that plug into the charger cord that stays on your battery. Battery tender is a charger/maintainer. Just plug it into the cord that attached to the battery. When not using the charger the cord is free for other things.What is a "Battery Tender"? I bought Shkciglightoutlet Motorcycle 12v USB Cigarette Lighter Power Port Integration Outlet Socket
by SharkMotorcycleAudio on Amazon. Is this safe? need Battery tender for this??
Thanks!
if you dont have one i recomend it. Keeps your battery at peak charge all the time. You hook a wire to your battery and place the end under your seat. You can then connect the tender to it, or a phone charger or any other 12 volt item to that cord.What is a "Battery Tender"? I bought Shkciglightoutlet Motorcycle 12v USB Cigarette Lighter Power Port Integration Outlet Socket
Thanks!
No, because the power isn't going anywhere.If I leave the harness connected to the battery will it drain it?
