Speed Limiter
esenior
Was wondering first if the 2015 FZ6R has a speed limiter built in.
Now I know I am probably going to catch some flak for this, but I actually want to LOWER the speed limiter. My son is getting a bit too crazy on the bike and was hoping I could slow him down a bit by reducing the limiter (assuming it has one). Anyone know of a programmer or a company that can custom program a lower speed limit? Would prefer to handle this myself so that it can be easily undone later.
Thanks....Eric
Marthy's right, the aussie version came out as a learner approved bike ( power/ weight limit) which was just a throttle stop. This pic shows the difference, the bottom one is unrestricted, having a cut off stop allowing 100% throttle.
This would be an expensive solution but it is an option.
The company is ecunleashed.com and they typically remove the factory ignition advance inhibitors from 1st, 2nd, and 3rd, then in some cases push the rev limiter out beyond factory settings.
That said, I would bet they may be able to reduce it too and keep it away from the happy spot. :eek:
The downside: shipping the ecu to a dealer/rep and the cost. They ding you $4 - 500 USD.
An option is used ecu (fleebay or a part out here), flash it to kill the joy and drop that in. Keep the original for later....
As I know it the older sibling the FZ6 the gauge retains the odometer info... these IDK!
Say if you wanted to make it a little faster, would it hypothetically be a bad idea to grind it down a little giving more power? I just want more kick from this bike
Are you in the US? If so then there would be no sense in grinding anything. At wide open throttle your throttle bodies are open as much as they could ever be. You cant get any more “wide open” than wide open. 😉
It may be different in some countries that use a throttle limiter plate or whatever its called.
