Leaking output shaft seal behind front sprocket
rscobie28
Pittsburgh pa
I noticed a small leak that at first thought was coming from the oil filter until I got under it and seen it was coming from behind the front sprocket. UPDATE: it is coming from the output seal. Something got under the sprocket and crushed the seal a little bit. Ordered one and is very easy to replace if anyone starts noticing a similar problem. Haven't seen any other posts about this other then it's not common on our bikes.
