How To: Tuner X (Ebay) Intergrated Taillight
iSpoolin
Beckley, WV
First off i'll add pictures at a later date, but I did this in the dark and in a hurry haha
Tools Needed:
Most of the tools you need are in the tool kit that came with your bike!
Phillips head screwdriver
Allen Key (the smaller one out of the tool kit im not sure of the size)
Wire strippers/cutters (if your going to use the intergrated taillight)
Things you will need just to make your job neater/safer once your finshed:
Wire Nuts (AKA Butt Connectors)
Electrical Tape
Zip Ties
Disassembly:
1.) Remove the rear/front seat
2.) Disconnect the positive battery terminal (your messing with electicity, its not alot but still when splicing wires you want no electricity running through it, don't be stupid)
3.) Remove the passenger grab rail, its held on my 4 allen head screws and has 4 washers under the rail once its off
4.) Loosen the tails side plasics, you can remove if you want, but its not needed, just remove the two plastic rivets towards the back of the front seat and pull both sides out
5.) Remove the 3 phillips head screws holding the tail light in place, you have to go at them from under the rear seat
6.) The tail lights held on a little with some rubber stops, just tug and it will come out, then remove the tail light bulb and set everything aside
Installing the intergrated tail light:
1.) Plug the yellow connector that comes from the tail light into the socket for the stock tail light bulb
2.) Reverse steps 5-1 for reassembly
Hooking up the turn signals
1.) Cut your turn signal wires and strip about a half inch of the sheath
2.) Run the turn signal wires from inside the tail (You should have ran them into the under seat compartment) theres two small holes in the bottom of the tail plastics that I used to run them down, one on the left and one on the right. the YELLOW wire is for the RIGHT turn signal and the BLUE wire is for the LEFT turn signal
3.) (Both sides do the same thing) Take the two exposed wire ends you have and twist them together, then screw a wire nut over them and wrap them in some electrical tape (Please do not leave exposed wires under the black tape)
4.) Tidy up the wires by taping ALL of them into a bundle (MAKE SURE YOU TAPED THE WIRE NUT CONNECTION ALREADY BEFORE YOU WRAP THE WHOLE BUNDLE TOGETHER!)
5.) Now with this step I don't know if everybody can do it the same, but I ran a zip tie through some holes in my fender eliminator and then strapped my bundle of wire to the back of my eliminator so that its out of sight :)
Install took me about 45 minutes and was probably the easiest thing i've done to my bike so far.
I'll update with pictures once it stops raining!
Did your Tail light not come with the steel clips that go right onto the prongs in the connector for the turn signal? That made it a plug and play job for me. I did not have to cut and splice any wires. The small Allen key is a 4mm key. Also, I didn't see where you mentioned about the yellow plug that goes into the brown tail light bulb socket. Just trying to help you perfect the write up. I should have done one last year when I got mine.
Mine came just had wires coming out, no metal clips....
oh and yeah I need to mention that, I was just overlooking it because its kind of self explanatory haha
If you buy the OEM connectors from Custom Led, you don't have to splice the factory turn signals. The OEM connectors have pigtails that you can splice onto the integrated taillight and then you can plug those into the factory (just like how the stock ones were put on). It is nice to not have to splice wires if you really don't need too.
Here is the link to the site. Fast shipping too!Motorcycle OEM Connectors for blinkers and tail lights
day two=:needpics:
lol jk
Very nice writeup, thank you! Overall how are you satisfied with the final quiality of the product?
day two=:needpics:
lol jk
I'll get them up tomorrow probably (if I can get time haha)
Overall it is 10000 times better then stock. Cleaned the tail of the bike up ALOT and even though its tinted its 2x as bright as stock
Mine should be here in a week...show est deilery first 1-2nd week in may...aor did your get to your place faster the estimated
Mine was scheduled to be delivered on the 21st of April but it got here on the 16th.
Plus the Ebay listing says Canada, but it came from Taiwan.
If you buy the OEM connectors from Custom Led...
I got my OEM plugs from 12oclocklabs. They are $5.99 a pair (2 x males - left and right). You can have them pre-wired and pre-crimped too!.
I don't know if selecting Yamaha WR250X/R will have the right color sequence. So when I got mine I just had them pre-crimped to 6" wires per terminal. Awesome!
Here's the link direct to the plugs:
Yamaha / Suzuki OEM Turn Signal Connectors
What did everyone do to remedy the fast blinking? I saw that one or two of the turn signal "energy sinks" says on them not to use for integrated LEDs...not sure why.
Best
Right best
Brake
Lol it's hard to take pics that actually show it... A video would be better but my iPhone is giving me a hardtime uploading it
