I recently purchase 2012 FZ6R with only 650 miles on it. Driven it home on the highway and elsewhere perfectly fine. The last weekend, I did 2 things.
1) I did an oil change (Mobile 1 4T Fully synthetic & K&N Filter).
2) Installed a GiPro X healtec gear indicator.
Now when I try to shift the gear after 5k rev, the gear seems to drop down 1 or 2 gears down. For example, I am on 5th gear and soon as I rev it higher than 5-6k rev, the gear indicator drops to 3rd or 4th gear. not just the gear indicator, but the actual gear it self, because the RPM goes from 5-6k to 8-9k (high rev) because it went into lower gear. This also happens on 6th gear and after 5-6k, it drops to 4th or 5th gear. I try to shift it up again, but the gear shifter is already in the 6th gear position and I don't have anywhere up to shift it. I have to down shift it match the gear it's actually in by engine rev and then keep the rev under 5k for it to not drop gear down again.
Could it be because I used fully synthetic oil? I read elsewhere, synthetic oil causes transmission to slip in older bikes (but mine is 2012 with very low miles (750 miles). Should I try the Yamaha lube instead?
Or could it be because of the gear indicator I installed? I did had to tap into the crankshaft sensor?
I cant stand this because soon as I shift the gear above 5k rev, the rev goes from 5k to 7-9k because it drops 1-2 gears down, even though the gear shifter is in the right position (ie- if I am in 6th gear and when it drops a few gears down, I cannot shift it up because the shifter position is on the 6th gear and nowhere to shift up. I have down shift a few gears down and slowly shift it up all while under 5k rev for each gear.
