Mart Man....no dumb A$$es or Bubbas here....OK, I feel like a dumb a**. I looked at my shock and I can see the preload ring with the numbers on it. But how do you know which number it's set at. I can't find a mark to indicate which # is the selected number. I had no issue finding the tool to adjust, but don't know where to go. Am I already at 7? Can't tell!!. Also found it's not too easy to get the tool in place and have room to turn it. The damn plastic from the fender is right in front of the ring. If you go to one side, the brake line tube is in the way and on the other side, you've got the chain guard to deal with.
I saw a previous post where one guy changed his setting on lunch break, so I must just be missing something. On the side with the break line tube I can see a very small yellow dot on a bracket, and some blueish paint across the bolt for the shock, but I think that's so the techs can see if you've messed with the bolt.
If someone's got a photo of where the marker is for position and how you go at the ring adjustment it would be great.
OK...cell phone pic at lunch to clear up the questions. I added red lines to the pic so you could see what I'm talking about.
1. The double dimple on the right side of the shock is the marker for the preload adjust number. Align the number to the double dimple.
2. The preload numbers are stamped into the ring AND the ovals are graduated from largest = 1 to smallest = 7.
3. The tool works from the right side and you can get it to turn 1 step at a time. It fits in from the right and you push it towards the front of the bike to add more preload. Use the extension handle for more leverage unless you have an iron palm.
The pic shows my preload at 7.
