UselessPickles
Could you point out what part of that article is relevant to the discussion of whether lower RPMs, more throttle, and taller gearing yields better fuel economy? All I see is a discussion of optimizing air intake and then determining whether you have a fuel system that can supply fuel at a high enough rate to maximize acceleration.
BTW - I was wrong about the most efficient way of accelerating being full throttle and short shifting. It would actually be full throttle and shifting at optimal points for max acceleration, then shifting into a higher gear as soon as you reach your cruising speed.
I'm now exiting this discussion. If I get around to researching this idea more and can work out a decent model of all the dominant factors involved, I'll enhance my full-throttle acceleration simulation code (read about it here; also featured here) to model fuel consumption and also partial throttle acceleration and start a new thread to discuss the results. Since I doubt I'll be able to obtain an efficiency curve for the FZ6R's engine, I'll probably have to end up using a "typical" efficiency curve and call it good enough for the purpose of showing general trends.
