Valve Shim OD
Half-Click Up
Active Member
Granbury, TX
www.youtube.com
Hey guys,
Getting ready to turn 56,000 miles and am gonna finally go ahead and perform the bike's first valve adjustment. Have a couple seconds of clatter on startup, too, which according to various R6 vids on YouTube, likely points to a stretched timing chain and possibly worn out chain tensioner.
With that being said, I plan to change timing chain, cam sprockets, chain tensioner, and adjust the valves.
QUESTION: Any idea what the OD of the valve shims are? I'm guessing it's 7.48 like most other Japanese inline fours?
Thanks!
Hey guys,
Thanks!
Howdy Half-click!
Would you mind posting your check results? My wife's 6r has 65,000+ miles with no check, just kind of curious.
Thanks, John
Howdy Half-click!
Thanks, John
Yes Sir, I most certainly will. It'll be a little while for me to piece together all the stuff... looking at like $280 to get the shims, sprockets, chain, gaskets, etc.
But, once I knock it out I'll post up the results.
Howdy Half-click!
Thanks, John
John,
I apologize for the extended delay, but here is a pic of my clearance documentation (58,000 miles):
Seven of sixteen valves were out of spec (they're highlighted). They're not terribly far off, but I believe the fact that it's nearly HALF of them may explain my cold idle issues. My plan is to shim those seven to the "half-way" point of the spec range.
John,
Thanks for that Half-click! Be interested to hear how the shimming goes as well. Might just attempt this myself.
John
I'm looking forward to your rebuild video :) I have to do my re-valving this off-season.
I filmed half of it today. Tomorrow the cams come out. It's SOOOO FRIKKIN' HOT here dude. I damn near fell out a couple times, so it's making it take longer to complete this project. I'm having to stop every couple hours to rehydrate and cool off inside for a bit. It's also a challenge to film the process. When I film a tutorial, it takes double the time to complete the task cuz of constant camera and angle setups.
It'll be a good one, though... I don't believe there is a single video tutorial out there for the FZ6R valve adjustment, not to mention I'm swapping the cam sprockets and timing chain, too!
