GHOSTWITTHEMOST
this has probably been posted but here it is anyway
GoPro HD Hero- Third Person High Speed Motorcycle Highway Run - YouTube
I need to make me one of those contraptions
I made one that was so awful I destroyed the footage along with pole and mount that scratched the *@$% out of my wife's 250 test bike.....
If you guys want minimal flexing you need to reinforce the hollow tube with a solid core. As light weight as possible.
What thicknesses are you using for poles?
Mine is a solid (not hollow) aluminum rod. I would say about 3/8" Diameter. About 3 1/2 to 4' long. No flex at all while trying to bend it in my hands, but mount it at the base and it goes all bouncy limp on me.
Have you tried handling it from the base and working your way up? :rof:
In all seriousness though, aluminum being a softer metal is more malleable/bendable than like steel, etc. When having it in your hands you aren't fixing it to one spot and applying weight to the opposite end... your hands have a lot of give to them as well. This may sound odd... but try using a hollow piece of metal conduit. The more I think about it, at the length it may have less play than a solid one. Totally eating my own words...if it's a solid piece of metal it will have more malleability then a hollow one with a different material inside reinforcing it.
I was able to pivot my bar very easily and took some fottage that way this morning got to check it out but I couls see it boucing around too much. what I need to d is a tripod version of this than it would be fixed to the bike and no bouncy bouncy pole that way.
That is my issue. I dont want it straight up above me. I want it directly behind me and angled so it looks like the video is from another rider REALLY close to me.
Flex = ENEMY. Will figure something out... Eventually.
Edit... Maybe run a piece of wire/rope from the end of the pole and tie the other end down to the passenger bar or foot peg??? Pull it tight so there is no more flex in the pole. That should stop the flex/bouncing. Hmmm....
