Thanks Ryan I appreciate you man. That will work!you either need to put a load resistor on each front or change the relay to one that does not have to see a load.
the factory flasher relay is designed to blink differently when the bulb blows. LEDs pull so little current that the flasher thinks the bulb is blown.
here is what I used.
Custom LED Electronic LED Flasher Blinker Relay - Plug And Play
ryan
Great info. Thanksyou either need to put a load resistor on each front or change the relay to one that does not have to see a load.
ryan
Do you have LEDs front and back? which relay setup did you use and what are your results? Did you have to use the Stage I Load Equalizers?you either need to put a load resistor on each front or change the relay to one that does not have to see a load.
ryan
That's the problem. The black wire (not striped on my bike or in the wiring diagram) is ground. Blue is the running light and brown ("chocolate," officially) is the turn signal. Your LEDs are floating between the running light and turn signal circuits, which is causing the out of sync flash.I have the LEDs for the rear but from a different manufacturer. The ones I put on in the front had 2 wires...yellow and black. The stock ends had 3 wires...blue, brown and black with lines on it. Directions say to tuck the black striped wire on both sides.
Just curious but would this be putting a load on my battery when its keyed off?That's the problem. The black wire (not striped on my bike or in the wiring diagram) is ground. Blue is the running light and brown ("chocolate," officially) is the turn signal. Your LEDs are floating between the running light and turn signal circuits, which is causing the out of sync flash.
Shouldn't. All the lighting circuits are disconnected from the battery with the key off.Just curious but would this be putting a load on my battery when its keyed off?
Still trying to get spider2k to show me what and where that flasher relay plugs into on the clutch side of the bike under our seat. Help me out spider!!! A bit off topic, Im thinking about tinting the headlight to match my smoked wind screen and blinkers. I'm just afraid that this would hinder my ability to be seen. What do y'all think?all you need is the $20 relay. our factory flasher relay is designed to cause rapid blinking when the load(resistance) on the circuit falls below a certain level to indicate a blown bulb. this is what we all call hyper-blinking or hyper-flashing.the "load equalizers" are just resistors.
the relay that i linked and bought does not have the same load requirement so it will blink at a set rate even with LEDs which register much less resistance than the filament inside an incandescent bulb. the filament inside is a resistor that gets really hot and glows.
it's plug and play and if you trim the tab at the top of it you can re-use the rubber mounting part from the original flasher. it's righ under the seat on the clutch side of the bike.
you can also make the two wire flush mount operate as a running/blinker with a couple of resistors and diodes. i over made mine using scrap plugs i found on eBay so that they are plug and play.
I think very bad idea. Although it would look nice, I'd rather be seen and not killed. We already have the chips stacked against us, so don't take your already limited visibility away. Just my $0.02.A bit off topic, Im thinking about tinting the headlight to match my smoked wind screen and blinkers. I'm just afraid that this would hinder my ability to be seen. What do y'all think?
i just put this in. actually i tried both of them and im still having the same problem with the strong rear leds and the really light leds up front. they are still out of sync. what else can i try? Please help!you either need to put a load resistor on each front or change the relay to one that does not have to see a load.
ryan
do i have to sneak a set of regular lights on here to get everything back to full brightness and full speed?i just put this in. actually i tried both of them and im still having the same problem with the strong rear leds and the really light leds up front. they are still out of sync. what else can i try? Please help!
