info was on youtubeOops! I'm assuming you kicked it as you were getting off.
Was out testing my 13.00 rear looking Go Pro mount that attaches to the grab bar and forgot it was there so as I dismounted I snapped the thing in half. Oh well, things happen.
I plan on taking this advice...I usually take a lanyard or something and attach it to my GoPro whenever I can. I've had a few of the plastic mounts break, thankfully not bad enough to send my GoPro flying.... also the suction cup works great most of the time, but if it decides to let go, it's gone!
If you do attach a safety, run it through the actual GoPro case (I loop through the holes in the door), not around the black plastic mount pieces.
search for Motorcycle Bike Bicycle Handlebar Mount For Contour GoPro+tripod + handle screw on the b-a-yWhat type of a mount are you using?
