stevet
Does anyone have a listing of common torque specs for the FZ6R?
Thanks! Where did you buy your repair manual?i will on the 6th when my manual shows up, if anybody needs specs post and i will answer your question.
This is a post from 2010. I don't think he's a member anymore. You can find downloadable versions cheap. I downloaded a copy for like $5 or $10. Just Google fz6r service manual. You'll find lots of stuff, just sort through some of the garbage links.Thanks! Where did you buy your repair manual?
Rick Forristall
I am using the PDF copy of the factory service manual that has been around since 2009. It calls for 57 Ft. Lbs torque on the rear sprocket nuts. That sounds too high, and when I try to tighten them to that value it feels too tight. Anyone know of an updated spec.?
Thanks.
Any specs for the fuel sender unit plate bolts?here's the rest !
left side gusset plate 4 bolts 22 ft lbs
union bolt oil cooler 45 ft lbs
rear brake disc 14 ft lbs
oil fillter 12 ft lbs
drain bolt 31 ft lbs
We use essential cookies to make this site work, and optional cookies to enhance your experience.
