51adwsu biker
I am getting a new intake and I have no idea how to install it or even how to get to the old intake......HELP?:surrender::surrender:
I've been using K&N on my cager for 115000 miles with a 3" ram air tube straight in the airbox with no problem at all. Not even the Mass Air Flow.i just have to put in my 2 cents, K+N and any cleanable filter is bad for your engine. i work for ford, and we wont warranty any air related issue with after market filters, and in school we learned yes they improve performance and gas milage but cut the life of your engine down by a large margin. the oil from the filter wicks back into the intake, which is famous for clogging up mass air flow sensors(see that way to often with mustangs) and also the more air going through the filter the more contaminents going through the filter too. K+N cold air intakes on diesel trucks are nick named diesel dusters and theres a 2008 f-350 thats been dusted, sitting in my bay at work right now. and all because of this air filter system letting dust contaminents through i have to pull his cab and replace thousands of dollars of parts. hes looking at a 12 grand bill all said and done. ill stick with my paper filters...
we always use a k&n air filter on race motors without a proboem. like you said, they just need to be properly cleaned and oiled. now on the track we always had a bra that went around it to keep the dust and dirt clods from getting into it. i wonder if something like that would work for our street use, or if that would restrict flow too much.The thing is they need to be clean on a regular basis with soft soap and oil. Now putting to much oil in the filter might be the cause of some of the problem you describe...
$$$$$$hit load!!!!!!:wav:4 to 6 H.P. is that all? With the whole 9 yards? HHMM seems hardly any advantage. However with the K+N filter/exhaust/ PCV or JB Pro,,,, is there any increase in mid-range torque over stock? L.P.
Dig into "R6 exhaust Marthy edition" There's few numbers in there. Stock was around 70, R6 Supertrapp w/o PCV was 68 with gain in the mid range but -2 over 9K, Supertrapp with PCV was 74. I haven't had the chance to do another run since the Viper.Now that to me is more important than H.P.! Any body ever take a stock 6R run it on a Dyno,got Torque figures, and compared the figures to a modded bike?
