Good old test light will do the job. Just disconnect the terminal and check witch one got juice. Won't be black... just got 2 options. I don't have "the book"...Hi, I just wanna have turning signals with only turning lights working and without running lights all the time on; I assume I gotta cut some wire, but I'm not sure which one (colour) I have to disconnect in order to have only flashes working. Can anybody help me?
i don't know that you'd get a fast flash for cutting the running light. flushmounts get the fast flash because the LED's don't have enough resistance for the bike to recognize there's actually a turn signal. therefore it goes into trouble modei believe that if you just want to cut a wire to keep the running lights from coming on, it may cause you a fast turn signal. my flushmounts are only two wire (no running lights) and it has a fast flash.
