Did the first fork oil change at 14000km.
Changed to Motul 15Wt synthetic fork oil.
Very easy to accomplish. The hardest part is to get the bike hung up from the ceiling or some other way to hold up the front. My front stand couldnt hook up the the lower triple clamp as it wouldnt fit well enough so I just strapped it from the handlebars to the ceiling. (Use a rear stand as well)
Remember to loosen the top cap before you remove the fork leg. Once the fork is off the bike just open the cap and pour out the fluid into a measuring cup. I got around 400ml per side. Then add that same amount of new fluid to the fork and re-install. When you remove the fork cap you can just open it up a few inches and you wont have any parts fall out.
The 15wt oil improves the damping of the fork a lot. Feedback and ride are much better. I think its still slightly fast on rebound so I'll try 20wt next time. Especially once it heats up.
Here are some pics of the old and new fluids...Looks real nasty at 14000km.
