kiggaxwut
I had a lowside a few weeks ago after taking a right hand turn top hot with cold tires and bad throttle input. Frame slider and rear brake lever took all of the damage as far as I can tell. I've noticed that in third gear if I crack open the throttle my revs increase but I'm not getting the pull of acceleration as before. I've seen from searching this could be either a throttle or clutch cable issue. It doesn't look like I have much throttle free play, but my clutch appears to work fine in lower gears. Any ideas?
