Ok, this is super simple and this probably didn't need to be done. This is for those of us with after market turn signals that blink really fast...
Purchase this...http://www.customled.com/products/flasher_relay/flasher_relay.htm and continue. I got mine in about 2 days.
Tools needed...none, if you just remove the passenger seat. I wasn't quite sure where the relay was so I removed the front seat and tray. Tools needed for that are 10mm socket and a 3/16 allen wrench.
The stock relay is located on the right hand side if you're in front of the bike. To remove the stock relay it's just held in by a rubber loop you can just wiggle it out. See attached pictures if you have any questions. Just unplug the stock relay and plug the new one in. It's really that simple.
First 2 pics are to whore my bike . Here was my assistant...
Here's some video...first one is the before and it's a little old...
[ame="http://www.youtube.com/watch?v=AL2znoDstuc"]YouTube - Blinker Flash OEM Relay[/ame]
Here's the after...
[ame="http://www.youtube.com/watch?v=WRfGeVA6yrQ"]YouTube - Custom LED Flasher Relay[/ame]
Here's the after...
