I found these Emergency vehicle grade LED's and mounted them on my black Raven. They come with emergency flash patterns built in but you have to use them in slave mode and you can only own amber so they're legal. Slave mode will only blink at the stock rate and they will blink in sync.
These are not the cheap dim crap that we find on ebay and the aftermarket places. These are legit emergency vehicle amber LED's. They are heavy duty, shatter resistant, fully encapsulated and waterproof. They come with everything you need for install except the drill.
Mine are side mounted using the stock holes in the front plastics and small drilled holes in the two rear plastics under the rear grab rails. These lights can be seen for almost a mile away even in the sun. When they are off they are clear and a very slight smoked color. When they are on they are as bright as tow truck lights. Even tho they are side mounted they have reflectors built into them so they are fully visible from front and rear.
Because of the very slight turned down angle of my install, they will not blind people next to you but they will see you for sure. No one will mistake or wonder which way you are turning or changing lanes again with these bad boys! Here they are and this is where I got em...
Sound Off LED3 Super LED Strobes N' More
