Flasher Relay Replacement How To & video of CustomLED ELFR-P 10 Function Flasher
Chris12
San Francisco, Ca.
I've already posted this write-up in my "mod" thread, but I made a new video and figured out how to embed media, so I wanted to repost it. I feel that other members wanting to change their stock flasher relay (to fix hyper flash after led installation) will benefit from this write-up, and the repost will benefit those searching thread titles.
Here is my newly edited and uploaded video that I made for both myself and CustomLED:
[ame]http://m.youtube.com/watch?v=Ko6M8TO6lz4[/ame]
Below is my install write-up with photos.
I installed my CustomLED ELFR-P 10-Pattern Programmable Electronic LED Flasher Relay with OEM Connector today and it was very easy. I knew that the unit required a dedicated ground which made me a bit uneasy but it worked out great.
ELFR-P Programmable Electronic LED Flasher Relay with OEM Connector Custom LED
Here's a quick run-down on how I installed the elfr-p on my 2012 FZ6r and a few videos of the 10 different functions.
This is the stock flasher unit underneath the rear passenger seat. The OEM unit is still mounted, but I already have it disconnected.
qjRz5dMrHfIG_HQEE1TLdO-uUkh8mUMmiknzMoEeFvO4fdDEKezFO_9r3HmBfgUV0L3Bb9Tulqg6fve6VkA37Nu8YuTC42U8IglCeMbW1ojvnrPbKI_j1FUxj-3F2FSs7ZjRkQ
Here is the area where the stock flasher unit resided, and where I'll mount the elfr-p.
-8Vyk_yRTdofUm55g6RQJlFsUo6sGhUxbgTmEf5eJOP72DMv1Gky97U5nVKPFWCdre2n89G3R9-b_QJ1sCr7QGH4276k7k-3oPSncvB1lX4hPwXe8RqEB1pg4Zu0pBgfgSY-MQ
Here's the stock flasher unit. It's attached to a rubber mount and the rubber mount attaches to the bike.
mw9wOmnyCEjxNPEQBMrsBpZsz4zRRxyH3Dh5aRpyrFZtu2xvD0IrgSN5MTS7aneQsO_DruU4TvRvKUh7FLXkXB92HFjd_Ov-8DIQA_vzZtfUjHG6XJAGqBGpM0Wamar8SBMiyw
These 10mm nuts are conveniently located in the same compartment. I removed the one closest to the front of the bike and ran the ground under the plastic/rubber shielding to the stud.
OBFZVJD6Y0k0X8KSd04yEz3bBbutkXtA4IYbMjVbtt6EUHplhRIw2x_Xb5NeVhkxNN0A-c4ajt0W7BT132dfZxLrVp7MaNQnTEIlD8eAP2eE-R3ixrnK5EYUu4ZmWk6_L2vJkQ
Here's the ground terminal slipped over the stud.
PEbiQ2PkUhC6FNgdLRwjOzInpzI2RN6gEZc1usV6-Fpm4DLhdWGck1iaxplkJ8xf0dVMmVzKFFbsPDwJKjTmsQ0WDP-XfSUNjOEdbDWu_Y-QI_ChtKRWtYi-qrSQhXG2uiDv7Q
Next, I used the supplied two sided tape to mount the elfr-p to the stock location. Note the white rectangle - that's the two sided take as I begin to peel the backing.
whjxTsZlZUd71qKlErM1JAcKvogbUuYy4pnkDcOu_jK_8qgtcsHmH6Y8GdWSEEABIZlZwZNq8JLt3ET5Vk8rAEQJajZW_ljQG3wWBsYWismLyX2ngb09cAMVxqu_5ItIIKjCeQ
And finally, here is the unit mounted. The dial is easily accessible to change the blinker/ signal pattern (when the rear seat is removed).
WKyFnZmfqdl8IJgb73K7RqOh_O3Wn6lPnjjX4AV32bcg8uF-n8Q25HnDOAO-9S5Rvki_BmQ_1ja6JsRVXtihPSuIciK-8ZP7NWEYztr1zuSCx3vYFNFcEmbgltcx6fH_uojwNA
I was very impressed with the way the elfr-p worked with my Motodynamic rear led tail in the sequential turn setting. My first video shows this:
[ame]http://m.youtube.com/watch?v=WjoOufy1-OI[/ame]
My second video is focused on my Yamaha LED Plus front turn signal:
[ame]http://m.youtube.com/watch?v=O_ynLGoeBUE[/ame]
What kind of front signals are those?
They're Yamaha Genuine Parts & Accessories: YME-FLB2F-00
LED Blinker Plus Front. I couldn't find them from any US sellers so I had to get them from Europe.
I dare say that they're brighter than the stock halogens.
uTz2YrflUBihmSsAXJKInGvD3MwRJm9FrlERTImcOAVJBmaTij07oSoU0gxYl_WQO88luI2XiGfnQT4SNJpdESSSawOkdDHQF__8-zWzz5OeDBn2aEmLyzwjhcsB4VB5y_h6AA
