cjmaverickg
Yesterday I went ahead and changed out the spark plugs, I know a little late, at 10,500 miles, after accomplishing that which went far smoother than I was expecting it to I get on the freeway later last night and at about 70 MPH in 5th Gear I gave it full throttle and the RPM's Red Lined then came back down when the clutch engaged. Thought to myself that was probably a one time thing but maybe not since it did it again this morning on the way to work. I haven't adjusted the clutch in a couple thousand miles, I'm not sure if that's what would cause it to slip a bit? Anyone ever have this issue or something similar? Also, any guides on adjusting the clutch because I'm tired of taking it to the shop since I have time now.
