steve97229
I'm trying to put a fender eliminator kit with the turn signals and need to know if the black wire is ground, or the color wire. Same with the license plate light.
Thanks!
Thanks!
Black is the ground for the turn signals and plate light.I'm trying to put a fender eliminator kit with the turn signals and need to know if the black wire is ground, or the color wire. Same with the license plate light.
Thanks!
For the back I believe that green and blue are the hot, depending on which side you are on.Yep, the general rule is Black is ground, yellow is the positive, and blue is the running light.
