Well,I had installed the MotoDynamics flush led turn signals, but I think they have a poor front visibility. So I bought a "Vader" style led turn signals, an adapter plates set, a resistor set, and a wire plug adapter set (for no cut the bike installation).I installed everything and it looks great.
Note: the turn signal stalk is wider than the plates hole, don't drill the plates because are very fragile (I broke one inner plate), so you must warm the bit in the stove and let the heat make the work.
And about the leftover flush turn signals... I put it in the rear fender for more rear visibility (without the resistors).
Regards!
Regards!
