I first installed the DMP/Motodynamic Integrated Taillight on my 6r and everything worked fine since it comes with an equalizer. I just installed the Proton flush mounts though, and the flush mounts work fine, but the rear turn signals are now messing up. Instead of flashing 1,2,3, 1,2,3, they're flashing outside, inside, outside, inside.
I know there are plenty of other people on here that have the same set up, so what did ya'll use to solve this problem? Neither the shop I use nor Cycle Gear were of any help, and when I researched the parts myself, there was a wide variety between prices, amps, and resistance for the equalizers. I haven't been able to figure out if there is any difference between a load equalizer and a flasher relay either. Suggestions?
