Ripley
I am struggling with the LED turn signal mod on my bike. I'm keeping the stock tail light. However, I am trying to install LED flush mounts on the front and LED signals on the rear. The flush mounts seem to work fine when the stock rear turn signals are installed, however, when I install the LED rear turn signals, the front will dim and flash simultaneously and the rear fail to illuminate. I have a TST Ind. flasher relay which has same results as the stock relay. I have confirmed the rear do illuminate if I move them to the front. I see some folks use a load resistor in place of the flasher relay but from what I've read you don't need both. Anyone have this issue and have any tips to resolve it?
