Finally got my GPS on the bike.
Purchased a Tech-Mount, Ram OEM cradle, Garmin wiring harness. Pulled tail light, cut insulation, exposed wires (blue is the positive), (black is the negative). Cut off unused Garmin wires, saved the power black, red and fuse. Fabricated connector and soldered it to the tail light wiring. Closed it all up with electric tape. Connected Garmin harness and threaded wire under seat, and between tank and frame. Secured it with zip ties. Turned the key and BAM have power to the Garmin 205W, cool! Now some pics.....
