FS: Koso heated grips
jjmaine
Active Member
Maine
Koso heated grips for sale. These are the ones that have 5 different heat settings with the switch right on the left grip. The switch lights up to indicate what setting you are on. I believe they are Koso Appolo grips but since the previous owner had them installed I cant be positive. They do work fine and he had them connected direct to the battery though you can hook them to a wire tyat comes on with the key.
