I have a 2001 Honda Recon 250 utility four wheeler with a problem...
You guys seems to have a good knowledge of engines and I don't have the extra money to take it to a shop.
Heres the problem:
A few weeks ago I noticed poor idle and lots of stalling out. I know that it had to be something like a clogged jet. So yesterday I opened up the carb and cleaned her out with a air compressor and carb cleaner. I put everything back together and when I tried to start her up she wasn't very happy.
The engine will run in neutral with the idle screw all the way in. The second I put it in gear and go somewhere is stalls. It seems to run a little longer when going down hill and dies fast while going up hill. I don't think it's getting enough gas. So I cleaned it 3 more times and all came to the same outcome, stalling out.
I was think about buying a carb kit and seeing if that helped but thought I would ask here and see if anyone else has any ideas.
Heres the problem:
