Fluid Checks / Daily-Monthly Checks
Berdani
OK, I am new to the motorcycle and FZ6R world, so here goes a dumb but important question.
What fluids (where are they located also) need to be checked on a regular basis. I know oil is a big one and I know to check the dipstick when bike is straight up (not on kick stand).
Are there any other fluids that need to be checked regularly, (I try to inspect as much as I can before every ride).
Thanks! PS - Bike was bought used, no manual.
abyss1406
if your bike is operating between 180 degrees F and 230 your fine, and there are no leaks underneath your bike you have no reasonable suspecion to check your coolant, just flush every two years.
Riccochet
I check tire pressure and oil level before each ride. Brake and coolant, unless there is a leak, I don't bother checking. Also give the tires a good once over looking for nails and puncture marks.
