bloodypulp
My bike won't start and code on display says d01 17 anyone know this code?
Yup, found the same thing. D01 17 is not an error code, but more like a pre-flight check. It should not have anything to do with the bike not starting. Apparently it is present any time you run a diag for codes.nothing specific to our bike, but a quick goggle search shows yamaha codes for that have to do with TPS... but for r6, a 14-20 is supposed to be good. kind of a startup throttle position check... not sure why a 17 would keep it from starting.
couple of the other older yamaha forums say, check the battery
