June 25, 2015: i will replace it. Cost is <$20.00 at local dealership. Thank you
best advice: do it the right way. you should take it off to work on it, and if you're already going through that effort, you might as well go for new.
Bent a clutch lever and want to repair or replace it...
Can I heat it and un-bend it? or do i just need to replace it?
thank you
thank you
